How To: THETA Z1 OLED Customize Text
The THETA Z1 comes with a 128x24 OLED display that you can display images and text on.
Using RICOH’s official documentation, I was able to quickly customize the display with theta360.guide branding. The documentation provides information on Broadcast Intent keys and values. If you are new to Broadcast Intent, see my article Simple Explanation of Broadcast Intent for RICOH THETA Development.
Code Example
If you are eager, this is the core code example in this tutorial:
        @Override
            setAutoClose(true);
            notificationAudioSelf();
            Intent oledIntentSet = new Intent("com.theta360.plugin.ACTION_OLED_DISPLAY_SET");
            oledIntentSet.putExtra("display", "plug-in");
            sendBroadcast(oledIntentSet);
            Intent oledIntent = new Intent("com.theta360.plugin.ACTION_OLED_TEXT_SHOW");
            oledIntent.putExtra("text-middle", "theta360.guide");
            oledIntent.putExtra("text-bottom", "great community");
            sendBroadcast(oledIntent);
Steps
Open Android Studio
Create Empty Activity
  • Create New Project
  • Create Empty Activity
Add pluginlibrary
Project: build.gradle
allprojects {
    repositories {
        google()
        jcenter()
        maven { url 'https://github.com/ricohapi/theta-plugin-library/raw/master/repository' }
App: build.gradle
dependencies {
    implementation 'com.theta360:pluginlibrary:2.0.0'
Set MainActivity to extend PluginActivity
The rest of the steps refer to MainActivity.java
You need to import PlugActivity with Alt-Enter.
Set plug-in to close
Put this line in onCreate
setAutoClose(true);
If the camera locks up. You can force close it by pressing the Wi-Fi button and holding down the power button.
Enable Plug-in to Control OLED
You need this step to allow the plug-in to control the OLED display. If you don’t set the display to “plug-in”, your intent to control the display will be ignored.
Set Your Message
There are two lines. If you extend beyond the display, the text will scroll.
Congratulate Yourself!
Dream and Build
If you want to have fun and learn more about plug-in development, join the RICOH THETA Dream and Build Contest.
How To: THETA Z1 Function Button Control
Overview of Application Development for the RICOH THETA Z1
#2
This is really cool. Shows a lot of potential for communicating info to the end user.
We can pull the settings information through the API and display whatever we want. Does the normal camera (not plug-in) display settings? I haven’t read the user manual yet. It doesn’t appear to be listed on this site yet: https://support.theta360.com/en/manual/
Have you seen the user manual for the THETA Z1? I’m curious on how to use the function button more effectively.
#4
Normal usage shows a fair amount of information. Setting for Shutter, Battery Level, Top 3 Active Plug-ins (which you can toggle through) and more. I’ll add some screenshots soon.
#5
Can you see additional settings? For example, my scuba one needs to show color temperature.
I’m also interested in showing this:
https://developers.theta360.com/en/docs/v2.1/api_reference/options/capture_interval.html
