THETA Magic Filters by EdOliver, Victor Altamirano
Now Available in Plug-in Store
This article was written by EdOliver and Victor Altamirano
See sample image 360 view
Uses OpenCv to process images and generates interesting filters for the camera in order to experiment later with haarcascades.
Filters:
  • Image Equalization (color).
  • Binarization of image or Threshold (Red, Green and Blue).
  • Grayscale.
  • Blur.
  • Erosion-Dilatation.
  • Negative
How it Works:
Once activated, we can select the desired filter using the “Mode” button, depending on the color that the Wi-Fi symbol has, it will be the effect that will be applied to the image.
  • Blue: Image Equalization (color).
  • Green: Image Binarization or Threshold (Red, Green and Blue).
  • Cyan: Grayscale.
  • Magenta: Blur.
  • Yellow: Erosion-Dilatation.
  • White: Negative.
  • Once the filter is selected, we only have to press the Shutter button to take the image and save it, the image will be saved in a folder called “Filtered Images”.
Note: when the filter is being applied the WiFi symbol will flash, until it stops blinking. Do not press any other button, this process takes 1 - 4 seconds depending on the filter.
Development:
The filters were made with the following code:
Image Equalization (color):
fileUrl = String.format("%s/%s_equalize.jpg", Constants.PLUGIN_DIRECTORY, dateTimeStr);
Mat rgbImage = new Mat(img.size(), img.type());
Imgproc.cvtColor(img, img, Imgproc.COLOR_RGB2YCrCb);
List<Mat> channels = new ArrayList<Mat>();
Core.split(img, channels);
Imgproc.equalizeHist(channels.get(0), channels.get(0));
Core.merge(channels, img);
Imgproc.cvtColor(img, img, Imgproc.COLOR_YCrCb2BGR);
Binarization of image or Threshold (Red, Green and Blue):
fileUrl = String.format("%s/%s_threshold.jpg", Constants.PLUGIN_DIRECTORY, dateTimeStr);
Imgproc.threshold(img, img, 127.0, 255.0, Imgproc.THRESH_BINARY);
Imgproc.cvtColor(img, img, Imgproc.COLOR_YCrCb2RGB);
Grayscale
fileUrl = String.format("%s/%s_gray.jpg", Constants.PLUGIN_DIRECTORY, dateTimeStr);
Imgproc.cvtColor(img, img, Imgproc.COLOR_RGB2GRAY);
Blur
fileUrl = String.format("%s/%s_blur.jpg", Constants.PLUGIN_DIRECTORY, dateTimeStr);
Imgproc.cvtColor(img, img, Imgproc.COLOR_RGB2BGR);
Imgproc.blur(img, img, new Size(25,25));
Erosion-Dialation
fileUrl = String.format("%s/%s_erodedilate.jpg", Constants.PLUGIN_DIRECTORY, dateTimeStr);
Imgproc.threshold(img, img, 0, 255, Imgproc.THRESH_BINARY_INV+Imgproc.THRESH_OTSU);
Negative
fileUrl = String.format("%s/%s_negative.jpg", Constants.PLUGIN_DIRECTORY, dateTimeStr);
Core.bitwise_not(img,img);
Source Code in GitHub Repo
