THETA X - Turn Off Client Mode Authentication
I have a ricoh theta x running in client mode.
Whenever I send a request to get the current state, take a picture etc… I need to provide the default credentials or else I get a 401. As soon as I add the creds in, the requests work fine.
Is there a way to turn this off and make a request without the credentials?
I’m assuming you want to stay in client mode.
Have you tried this option?
_authentication
I have not tested it. If it resolves the problem, please mark the solution as solved. Otherwise, please post again with the error message and I will try and replicate it.
I have executed the following command.
POST
    "name": "camera.setOptions",
    "parameters": {
        "options": {
            "_authentication": "none"
And I get the following 403 response.
    "error": {
        "code": "disabledCommand",
        "message": "Command executed is currently disabled."
    "state": "error"
Just to confirm that you are running the command above in Access Point mode, right? After you set it to _authentication: “none”, then you go to client mode, right?
X Test with firmware 1.10.1
I’m using X firmware 1.101…
"firmwareVersion":"1.10.1","manufacturer":"Ricoh Company, Ltd.","model":"RICOH THETA X",
Set _cameraControlSource to “app” prior to setting _authentication.
Set _authentication to none
Verify _authentication
Z1 Test for Comparison
Result: Z1 works as expected
"firmwareVersion":"2.01.0""manufacturer":"RICOH","model":"RICOH THETA Z1"
Testing THETA X with no authentication.
Result: I can’t get the X to work with no authentication at the moment.
Testing THETA Z1 with no authentication
Result: THETA Z1 takes picture in client mode with no authentication.
curl -H "Content-Type: application/json" -X POST "http://192.168.2.200/osc/commands/execute" -d $'{"name": "camera.takePicture"}'
update May 12, 2022
This may be a limitation of the THETA X right now.
We hope that this will be improved in the future.
