theta-client continues to improve. These are the changes moving from 1.8 to 1.9. RICOH recommends updating to the most recent version.
Changes from 1.8.0
- _ethernetConfig option is now available, possible to set IP address as
staticordynamic, setipAddress,subnetMask,defaultGateway, and_proxy- current settings can be found using camera.getOptions, settings can be changed using camera.setOption
- Added new supported values to fileFormat option:
{“type”: “mp4”,“width”: 7680,“height”: 3840, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 10}
{“type”: “mp4”,“width”: 7680,“height”: 3840, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 5}
{“type”: “mp4”,“width”: 7680,“height”: 3840, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 2}
{“type”: “mp4”,“width”: 5760,“height”: 2880, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 30}
{“type”: “mp4”,“width”: 5760,“height”: 2880, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 15}
{“type”: “mp4”,“width”: 5760,“height”: 2880, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 10}
{“type”: “mp4”,“width”: 5760,“height”: 2880, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 5}
{“type”: “mp4”,“width”: 5760,“height”: 2880, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 2}
{“type”: “mp4”,“width”: 3840,“height”: 1920, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 60}
{“type”: “mp4”,“width”: 3840,“height”: 1920, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 30}
{“type”: “mp4”,“width”: 3840,“height”: 1920, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 15}
{“type”: “mp4”,“width”: 3840,“height”: 1920, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 10}
{“type”: “mp4”,“width”: 1920,“height”: 960, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 60}
{“type”: “mp4”,“width”: 1920,“height”: 960, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 30}
{“type”: “mp4”,“width”: 2752,“height”: 2752, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 30} *1
{“type”: “mp4”,“width”: 2752,“height”: 2752, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 10} *1
{“type”: “mp4”,“width”: 2752,“height”: 2752, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 5} *1
{“type”: “mp4”,“width”: 2752,“height”: 2752, “_codec”: “H.264/MPEG-4 AVC”, “_frameRate”: 2} *1*1 RICOH THETA X firmware v2.50.1 or later. This mode outputs two fisheye video for each lens. The MP4 file name ending with
_0is the video file on the front lens, and_1is back lens.
Added new supported values to _maxRecordableTime option:
300, 1500, 3000 (*1), 7200 (*2)
(*1) THETA Z1 Version 3.01.1 or later, only for 3.6K 1/2fps and 2.7K 1/2fps.
If you set 3000 seconds in 3.6K 2fps mode and then set back to 4K 30fps mode, the max recordable time will be overwritten to 300 seconds automatically.(2) THETA X Version 2.00.0 or later, only for 5.7K 2/5/10fps, 8K 2/5/10fps, and 2.7K2.7K 2/5/10fps.
If you set 7200 seconds in 8K 10fps mode and then set back to 4K 30fps mode, the max recordable time will be overwritten to 1500 seconds automatically.
