I don’t have OpenVSLAM running at a reasonable speed in real-time and thus cannot speak from actual experience. I suspect that the processing power will be a problem and that the system will be too slow. You may need to run the analysis against video files.
You may be able to rent a Z1 to test. For example, the site below offers the Z1 for $30 for a weekend.
You could also try and buy the Z1 and return it after a quick test.
I suspect it will be too slow for real-time OpenVSLAM with a larger map. However, I have not tested it. I can’t even run it at a reasonable speed on my old system.
That would be a big help as I never took the initiative to test OpenVSLAM fully. I feel that there is a lot of interest in OpenVSLAM from researchers. It would be great if you could share your findings.
