I have had a Theta z1 for a few days. I find that I can charge the battery to only 96%. Do more users have this problem?
I am using the same cable that came with my THETA.
I am using a 2 amp wall charger
I would guess that it is some type of calibration issue. The charge may actually be at 100% but the camera software interprets that same info as 96%. I would try doing a hard reset. Next, let the battery run all the way down before recharging.
I also like to use a charge monitor with my Theta…Then I know if it is actually charging or not. This is the one I have –
