Run node applications, including a database inside your RICOH THETA. I’ve summarized tips from 5 articles into a new article on DZone.
This is built up from these articles:
- How To Set Up a Linux Environment in the THETA to Control the Camera With Bash, Ruby, Python
- Easy Hacking of LEDs and Camera Using Termux
- Creating a WebUI with Node Running Inside the Camera
- Auto-start Node Application When Termux Plug-in Starts
- MongoDB Compatible NeDB JavaScript Database Running inside THETA
If you want to prototype a WebUI or other functions on the THETA, check out the article. This technique is not for production applications.
