Please advise on camera model and firmware. I have tested with a single command successfully. Testing with the two options in sequence failed.
I suggest a reasonable workaround is to run setOptions twice, once for just dateTimeZone
with only that option set. The second time, set all your other options.
Test 1 - single command on Z1, firmware 1.60.1, dateTimeZone only
Result: success
Test Environment
"firmwareVersion": "1.60.1",
"manufacturer": "RICOH",
"model": "RICOH THETA Z1",
Command
{name: camera.setOptions, state: done}
{dateTimeZone: 2020:05:18 01:04:29+08:00}
Result
check options with getOptions
successful
"dateTimeZone": "2020:05:18 01:05:08+08:00",
Test 2 - Multiple options, including dateTimeZone
Result
Failure.
Failing with multiple commands is one of the commands is dateTimeZone
. Will continue to test. In the meantime, suggest you break up the setOptions into two commands.
Test 3 - set multiple options, without dateTimeZone
Check to see if multiple options can be set in general.
Result
Success.
Payload
"exposureDelay" : 0,
"exposureCompensation": 0.7
Test 4 - set multiple options with dateTimeZone as last option
Checking if dateTimeZone takes longer to save to persistent storage.
Result
Fail
Option Payload
"exposureCompensation": 0.7,
"dateTimeZone": "2020:05:18 01:04:29+08:00"
Test 5 - Set Options Individually in Script
Set options individually. No delay between options. Functionality should be comparable to setting
multiple commands.
Result
Success
Script Used for Testing
#!/usr/bin/bash
# set individual options one at a time
# set first option
./theta.exe setOption --name=dateTimeZone --value="2020:05:18 01:04:29+08:00"
# HTTP session is automatically closed
# next option is set with no delay
# set second option
./theta.exe setOption --name=exposureDelay --value=0
