I recently saw a question on GitHub about getting a stream from an SC2 to a computer for processing by an application.
As the SC2 uses a different OS from the V, Z1, and X, it is not possible to stream over a USB cable.
However, it may be possible to use livePreview motionjpeg.
I previously wrote about this technique here:
At the time, I only tested it with an X.
I decided to test it with a RICOH THETA SC2.
git clone git@github.com:codetricity/ricoh_theta_mjpeg_opencv.git
Setup Python virtual environment and install dependencies.
python -m venv venv
source venv/bin/activate
pip install requests
pip install requests.auth
pip install numpy
pip install opencv-python
run
python main.py
