RICOH THETA API and HTTP HEAD
Originally published at: RICOH THETA API and HTTP HEAD -
HTTP HEAD is a method to request the HTTP headers from an API endpoint. This method is not supported by the RICOH THETA API and should not be used as the behavior across models appears to vary.
I recommend you use the http://192.168.1.1/osc/info instead to check if the camera is connected to your mobile app.
A developer recently asked about the behavior of the RICOH THETA camera models when an HTTP HEAD request is sent.
These are the result of my unofficial community tests.
model: Z1
result: returns header
curl –head http://192.168.1.1
HTTP/1.1 404 Not Found
Connection: Keep-Alive
Transfer-Encoding: Chunked
model: SC2
result: hangs
*** NO RESPONSE ***
model: X
result: responds the same as Z1
