so I have been able to get the plugin working - so I can stream live now - - hooray!
The question I have is – is there a way to marry the video from the camera - to the quality audio from my soundboard to the stream so it sounds great?
sorry, I don’t think you can change the audio source with the plug-in.
If you want to use another audio source, you would need to stream with a USB cable to a laptop and then select the alternate audio source with OBS.
I believe that the THETA output in live streaming is only mono, single channel (I’m not sure).
There’s no way to get spatial audio streaming from the THETA without special equipment as far as I know.
