Theta camera does not appear as a /dev/video device except if you use a special driver.
Check if the camera appears with lsusb and wi-fi switch to off for the theta.
I think I had to remove ‘GVfs’ (GNOME virtual file system) in order to use ptpcam or gphoto2
sudo chmod -x /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
sudo chmod -x /usr/lib/gvfs/gvfsd-gphoto2
restart Pi
We follow your advice and reboot Rpi.
It is still not working.
We try every mode of Theta V, it shows us like this:
Camera mode: Events receiving error. Capture status unknow.
Video mode: PTP: access denied. Error: Could not capture.
Live mode: PTP: Device busy. Error: Could not capture.
We change our Rpi. Now it is Raspberry Pi 4(raspbian os 64-bits) and ricoh theta V. It is still not working.
Is it caused by the USB cable or the OS in Rpi?
We use sudo apt remove gvfs-backends and it still not work for us.
And we noticed that you use theta instead of ptpcam.
We want to use the command like yours(theta --info, theta --capture).
What should we download?
The theta is my example is the same as ptpcam. I renamed it after I modified ptpcam so that I could test the original ptpcam and the modified version for comparison.
Thanks for your help!!!
We finally finished it.
We referenced the following URL and debugged it.
(URL:Raspberry Pi4 + RICOH THETA V でライブストリーミング) Note: The steps in the URL may not be complete, but only some installation packages are missing.
And, your advices are really helpful for us. Thank you a lot.
