Hi!
Would like to show you my Theta Z1 first of all:
And now the longer story:
I picked this camera because
- its sensor size and because
- it can connect to WiFi and
- according to specs it’s able to livestream via WiFi while
- charges from external battery.
Unfortunetelly these are not completelly true, at least not like I would love to.
I installed the module and tried testing. Results were disappointing, I think as is that plugin allows only 2k resolution and honsetly it was also breaking a lot,like the stream hangs every 2-3 seconds whichever option I choose on web UI. Also the same happens actually when I see the camera preview on my andorid mobile using Ricoh software…It may be related to preview framerate.
I got the code of Wireless streaming plugin and started to analyze, get in touch with the API, etc. At the beginning my conclusion was:
- Camera gets extremly hot in about 15 minutes and it turns off regardless of settings
- Quality of stream is very bad as is.
Anyway to make this short I modified a bit wireless streaming plugin to stream 4k, also added some heatsinks to it’s body. I was also playing with framerates as I wanted to minimize bandwidth required for my needs and I do not need 30 FPS.
I realized if I want to make sure I need a dedicated media server to be able to develop the application I need, so setup one and feeded with Theta Z1, doing more and more tests upcoming weeks. Anyway I realized soemthing interesting: this camera can do HDR live streaming too. I’m referring to RicStillCaptureMultiYuvHdr shooting mode. I was able to make it work, the only issue is that its working without stiching, I mean stiching doesn’t work as it should.
BUT the image quality, etc. colors, all is much better there.
Correct sample video to watch is below in a reply.
Any of you have thoughts how to improve/correct that stiching without slowing down extremly? Anyway to alter a bit static stiching of this cam through API?
Thanks in advance!
Regards,
Laszlo
