Dual-Fisheye image using USB API
verified this works with ptpcam
set to no-stitching (dual-fisheye)
ptpcam --set-property=0xd834 --val=0x0002
Camera: RICOH THETA Z1
'UNKNOWN' is set to: 0x0001 (1)
Changing property value to 0x0002 [(null)] succeeded.
ptpcam --capture
Initiating capture...
Object added 0x00000018
Capture completed successfully!
 ptpcam --set-property=0xd834 --val=0x0001
Changing property value to 0x0001 [(null)] succeeded.
ptpcam --capture
Object added 0x00000019
Camera Firmware Info
Z1 2.10.3
ptpcam --info
THETA Device Info
Model: RICOH THETA Z1
  device version: 2.10.3
  extension ID: 0x00000006
  image formats supported: 0x00000005
  extension version: 0x006e
Static Stitching
Appears to work
theta --set-property=0xd834 --val=0x0003
Changing property value to 0x0003 [(null)] succeeded.
craig@jetson:~/Documents/tools$ theta --capture
Object added 0x0000001b
oh, i’m working for the same project as Siwook_Choi.
we need fast still image capture (with or without stitching).
What is the time between images for unstitched images on the Z1 when you use the USB API?
I’m assuming this is JPEG, 6720x3360
@biviel I’ve seen “time reduction” requirement many times before. People are trying to save even 0.5 seconds on the time between images because they take thousands of images. I’m curious as to how fast they can take it with the USB API.
with stitching 0.294 image/sec and without stiching 0.367 image/sec.
we do not download image, just trigger and store images in camera.
log w/ stitching:
teevr@teevr-NucBox5:~$ rostopic hz /photo/shooting
subscribed to [/photo/shooting]
no new messages
average rate: 0.293
        min: 3.413s max: 3.413s std dev: 0.00000s window: 2
no new messages
no new messages
average rate: 0.293
        min: 3.402s max: 3.413s std dev: 0.00533s window: 3
no new messages
no new messages
no new messages
average rate: 0.292
        min: 3.402s max: 3.472s std dev: 0.03067s window: 4
no new messages
no new messages
average rate: 0.294
        min: 3.318s max: 3.472s std dev: 0.05472s window: 5
no new messages
no new messages
no new messages
average rate: 0.294
        min: 3.318s max: 3.472s std dev: 0.04917s window: 6
no new messages
no new messages
average rate: 0.294
        min: 3.318s max: 3.472s std dev: 0.04519s window: 7
no new messages
no new messages
average rate: 0.294
        min: 3.318s max: 3.472s std dev: 0.04232s window: 8
log w/o stitching:
verage rate: 0.405
        min: 2.472s max: 2.472s std dev: 0.00000s window: 2
no new messages
no new messages
average rate: 0.389
        min: 2.472s max: 2.675s std dev: 0.10161s window: 3
no new messages
no new messages
average rate: 0.383
        min: 2.472s max: 2.685s std dev: 0.09815s window: 4
no new messages
average rate: 0.379
        min: 2.472s max: 2.712s std dev: 0.09557s window: 5
no new messages
no new messages
average rate: 0.371
        min: 2.472s max: 2.936s std dev: 0.14740s window: 6
no new messages
no new messages
average rate: 0.370
        min: 2.472s max: 2.936s std dev: 0.13516s window: 7
no new messages
no new messages
average rate: 0.367
        min: 2.472s max: 2.936s std dev: 0.13422s window: 8
thank you again for your help. the documentation is now updated to show support for the Z1.
https://api.ricoh/docs/theta-usb-api/property/image_stitching/
I think ‘X’ is a typo. we are talking about the Z1 model here.
Thanks! I updated my last post. :slight_smile: Appreciate the help.
