Dual-Fisheye Images Using v2.1 (Wi-Fi) API
Sample Image
The new Wi-Fi API allows the images of both the Z1 and the V to be taken in dual-fisheye mode. Click on the image above to download a sample from the RICOH THETA V.
https://developers.theta360.com/en/docs/v2.1/api_reference/options/_image_stitching.html
The API works both from inside of a plug-in as well as a mobile app.
example
using Restlet Client
metadata
ExifTool Version Number         : 10.80
File Name                       : R0010009.JPG
Directory                       : .
File Size                       : 4.7 MB
File Modification Date/Time     : 2019:06:10 16:12:49-07:00
File Access Date/Time           : 2019:06:10 16:14:00-07:00
File Inode Change Date/Time     : 2019:06:10 16:14:00-07:00
File Permissions                : rw-r--r--
File Type                       : JPEG
File Type Extension             : jpg
MIME Type                       : image/jpeg
Exif Byte Order                 : Big-endian (Motorola, MM)
Image Description               :
Make                            : RICOH
Camera Model Name               : RICOH THETA V
Orientation                     : Horizontal (normal)
X Resolution                    : 300
Y Resolution                    : 300
Resolution Unit                 : inches
Software                        : RICOH THETA V Ver 3.00.1
Modify Date                     : 2019:06:10 16:12:49
Y Cb Cr Positioning             : Centered
Copyright                       :
Exposure Time                   : 1/200
F Number                        : 2.0
Exposure Program                : Program AE
ISO                             : 64
Sensitivity Type                : Standard Output Sensitivity
Exif Version                    : 0230
Date/Time Original              : 2019:06:10 16:12:49
Create Date                     : 2019:06:10 16:12:49
Components Configuration        : Y, Cb, Cr, -
Aperture Value                  : 2.0
Brightness Value                : 5.12
Exposure Compensation           : 0
Max Aperture Value              : 2.1
Metering Mode                   : Multi-segment
Light Source                    : Unknown
Flash                           : No flash function
Focal Length                    : 2.6 mm
Warning                         : [minor] Possibly incorrect maker notes offsets (fix by -84?)
Maker Note Type                 : Rdc
Firmware Version                : 3.01
Serial Number                   : (00000000)00105377
Recording Format                : Unknown (0)
White Balance                   : Auto
Color Temp Kelvin               : 5000
Accelerometer                   : 34.46 -57.47
Compass                         : 132.93
Time Zone                       : -07:00
Flashpix Version                : 0100
Color Space                     : sRGB
Exif Image Width                : 5792
Exif Image Height               : 2896
Interoperability Index          : R98 - DCF basic file (sRGB)
Interoperability Version        : 0100
Exposure Mode                   : Auto
Scene Capture Type              : Standard
Sharpness                       : Normal
GPS Version ID                  : 2.3.0.0
GPS Img Direction Ref           : Magnetic North
GPS Img Direction               : 132.93
Compression                     : JPEG (old-style)
Thumbnail Offset                : 2448
Thumbnail Length                : 12794
Image Width                     : 5792
Image Height                    : 2896
Encoding Process                : Baseline DCT, Huffman coding
Bits Per Sample                 : 8
Color Components                : 3
Y Cb Cr Sub Sampling            : YCbCr4:2:0 (2 2)
Aperture                        : 2.0
Image Size                      : 5792x2896
Megapixels                      : 16.8
Ricoh Pitch                     : -57.47
Ricoh Roll                      : 34.46
Shutter Speed                   : 1/200
Thumbnail Image                 : (Binary data 12794 bytes, use -b option to extract)
Light Value                     : 10.3
Update: June 10, 2019 Afternoon
I heard back from the author of theta4j that he will add this API to his library. :slight_smile:
Update: June 11, 2019
Sample plug-in available.
Update: June 12, 2019
New topic started for this developer template. Feel free to modify this template and submit your plug-in to the Dream and Build Contest.
