Originally published at: Remove Pineapple Icon on Z1 - RICOH THETA Developer Community
The weird pineapple icon on the Z1 is the remote control icon. If you see this icon and want to get rid of it, you can turn it off from the plug-in menu on the body of the camera.
Put Camera in Plug-in Mode
Press and hold the mode button. This is the third button from the top on the side of the camera.
Cycle Through Plug-ins to Select Remote Control App
If you have multiple plug-ins installed and active on the Z1, you may need to press the mode button quickly (less than 2 seconds) to cycle through the available plug-ins.
I have the remote control plug-in at position 3.
Short Press Mode Button to Change Active Plug-in Menu
In this example, I pressed the mode button twice to cycle to the third plug-in.
Press Shutter Button to Activate Plug-In
Press Shutter Again to Toggle Remote Control On or Off
Verify That Is Off
As the shutter button toggles the remote control on and off, make sure the pineapple is gone.
Exit Plug-in Menu
After verifying that the pineapple is gone from the plug-in menu on the body of the camera, short-press the mode button to select the exit icon on the body of the camera OLED.
When the exit icon is selected, press the shutter button.
Pineapple is Gone
