THETA X Firmware 2.30.0 Available
THETA X firmware 2.30.0 is available. For plugin development, the API has been updated to enable camera power off with broadcast intent.
THETA X firmware v2.30.0 (2023.10.17)
Plugin
  • It is now possible to select “5.7K (10 fps)” and “5.7K (2 fps)” for the video size in the shooting settings on the camera.
  • Cameras with serial number starting from “YR13” can now use the W58 frequency range in the wireless LAN client mode.
  • The W58 frequency range cannot be used in countries and regions other than Taiwan because the wireless certification related to the W58 frequency range has not been acquired.
  • The problem that the wireless LAN function cannot be turned ON when the wireless LAN frequency band is set to 5 GHz has been fixed.
