I previously wrote about the range of improvements to the THETA X with the 2.50.2 firmware.
Recently, I also found that the USB API was improved. prior to these tests, I disabled the auto-mount feature of Ubuntu 22.04
take picture
gphoto --trigger-capture
show summary info
gphoto2 --summary
Camera summary:
Manufacturer: Ricoh Company, Ltd.
Model: RICOH THETA X
Version: 2.50.2
Serial Number: 14113409
set to video mode
gphoto2 --set-config=5013=32770
start video
gphoto2 --set-config movie=1
stop video
gphoto2 --set-config=/main/actions/opcode=0x1018,0xFFFFFFFF
take 10 second video, then stop
gphoto2 --set-config movie=1 --wait-event=10s --set-config movie=0
take 30 second video, then stop
gphoto2 --set-config movie=1 --wait-event=30s --set-config movie=0
put camera to sleep
gphoto2 --set-config=/main/other/d80e=1
wake up from sleep
gphoto2 --set-config=/main/other/d80e=0
set to still image mode
gphoto2 --set-config=5013=1
set to interval shooting mode
put in live streaming mode
gphoto2 --set-config=5013=32773
put in still image mode from live streaming
Have not tested for long periods of streaming
set to multi bracket shooting mode
gphoto2 --set-config=5013=32772
confirm live streaming on Linux
NOTE: l learned from RICOH that the specifications for the API does not include the ability to send MTP commands when the camera is streaming. I confirmed the expected behavior in my tests. The stream did not stop when I was viewing the stream. However, when I stopped the streaming application, I was able to switch from live streaming to still image. At this point, I could not get camera back into streaming mode with the API.
summary
USB API is improved in my tests. Prior to the firmware upgrade to 2.50.2, I saw inconsistent behavior with image capture and changing the camera mode. In my recent tests, the behavior is consistent.
