Connect Ricoh Theta y1 Camera with server
Hello every one
I made it that I connect the Camera with API and javascript and php everything worked
PHP code :
` $Parametrs =$_POST['TakeNewPic'];
$opts =
  array(
       "user" => "THETAYN10113693",
      "password" => "10113693",
      "name" => $Parametrs
   $post = json_encode($opts);
$context  = stream_context_create(array(
'http' => array(
     'method' => "POST",
     'timeout' => 60,
     'content' => $post,
     'header'  => "Content-Type : application/json"
$url = 'http://192.168.1.1/osc/commands/execute';//.$https_server;
$result = file_get_contents($url,false, $context);
echo($result);`
but now they want of me Connect the Camera with Server not with Client ? and i don’t know what the mean? they told me that this IP :192.168.1.1 can change to another one when we connect with server
I want someone to explain this to me, even if in general, so that I can search in Google, I want points or keywords
After you get it working with the server, this is a concept/example of image processing
Building a Web Site for 360 Images with Django, Bootstrap, A-Frame - #5 by codetricity
If the camera is in a secured office, you can disable digest authentication in client mode.
Notice of website closure
