Is there any way of disabling Rioch Theta wifi. I need to use the camera where wifi is prohibited so I want to be able to disable it completely. Would be thankful for any hints.
Regards
Zain
Regards
Zain
Good day:
Of course you can!! on the Theta V and S simply by pressing the middle button, you connect and disconnect the wifi when you want.
That way the camera consumes much less.
a greeting
With plugin there is broadcast intent to control WiFi. In the plugin library there is helper method for this: notificationWlanOff
