Lens replacement in Ricoh Theta X
Unfortunately, our camera gets a little scratch on the front lens.
Is there any place in the world that sells new lenses/glass to Ricoh Theta X?
Best regards,
Kamil Kuklewski
There is likely a service center that can replace the entire lens assembly.
You can read the article below on what other people have tried. The best solution is to have the lens assembly replaced by a professional repair center
Disgusting philosophy or simply a poorly designed product that leaves the consumer to carry the hefty, brunt repair costs for a product prone to damage by default.
By poor design and over time, the camera lens (as it is removed or replaced into the supplied leather body protection case) will make contact with the felt material lining. This lining will scratch the thin, glass coating on the camera lens before effectively rendering the quality as unusable. The weakest link of any camera is the lens. This lack of foresight is a quality control issue and if not corrected by the manufacturer, this issue should be associated with a class action law suit to recompensate all those who replaced these units with new units or were compelled to buy into the bogus “repair” scheme authorized by Ricoh.
