Theta v
Turn off the device and the green light turns on, causing the [battery to run out quickly]. What is happening? Framware 3.10.1
https://drive.google.com/file/d/1Jifq7hHp-ra2lAIuyW_4ZOR9CbCenA7z/view?usp=sharing
Theta v
Hi, @nuikapi
To avoid the battery drain, you should shut down the camera with long press of power button.
Good luck.
Toyo
Thank you for answer
Normally shut down Green light is not on forever Or the battery is deteriorating
The camera has been used for 2 years.
