I have also notice that “httpConnection.startLiveView” method is consuming 100% CPU time. which is causing the issue. I have removed all the code inside this method just receiving the Data as a response but it is consuming 125% of CPU time.
Could you please provide us the direct live streaming view so that we can use that url in webview iOS Swift.
@jcasman and I have a meeting with RICOH on Thursday. We will organize and relay the information on to them
@jcasman has a Mac and an iPhone and will try to replicate this problem
unfortunately, I do not have a Mac, but I am trying to borrow one. the problem is that I need to install 30GB of Xcode on someone else’s Mac and I’m not sure they will be happy with that situation. I have an iPhone that I can use for testing.
i’ll test the SDK on Android, which is not immediately helpful, but could help to identify the problem indirectly.
Connected by Wi-Fi to THETA Z1, using firmware 2.00.1
Video appears to be smooth. It does not appear to stick every 2-3 seconds as described. I’ll post a video of my test soon. I’ll send an email to get more information from you on the problem you are experiencing.
I’m also using the same SDK but my device is XR, and iOS version is 14.0.1. The SDK is very laggy even I’m not able to scroll the images easily. That is not an issue We have fixed it at our end. but the only issue is live streaming. It would better if you can schedule a meeting with me today if it is possible.
I bought a MacBook Air yesterday for the test at the local Apple store, but now I need to buy an USB-C to USB-A adapter to connect the physical device iPhone. I ordered the adapter online.
@jcasman has the livePreview working on iOS 14.7.1 with Z1 firmware 2.00.1. He’s trying to set up a meeting with you to collect more information on your setup.
@max_a I’m available now or 11:30am PDT (in 15 minutes from now). Can you confirm what time would work for you? Probably just need 10 minutes or so. Sending a DM as well.
I hope you are doing good, We are facing one more issue, I want to communicate with camera using Bluetooth instead of wifi. Because if I connect camera with wifi then I’m able to access the internet. So I want to do this via bluetooth. Please let me know if you have a SDK which support bluetooth connectivity
I hope you are doing good. I’m facing one issue while connecting to Bluetooth. I have written the code to get the services and respective characteristics, But I’m not able to read or write anything.
I’m getting below Error.
" Error Domain=CBATTErrorDomain Code=1 “The handle is invalid.” UserInfo={NSLocalizedDescription=The handle is invalid.}"
I have already gone through the document link, I’m getting the services and characteristics but I’m ended
with below error.
Optional(Error Domain=CBATTErrorDomain Code=1 “The handle is invalid.” UserInfo={NSLocalizedDescription=The handle is invalid.})
Please help me, I’m completely blocked. I didn’t find any sample code on google or anywhere else. Your help would be appreciated if you provide me the sample code.
