SC2 thumbnail problem
Problem Description
In testing the THETA WebAPI, we found that getting a listing of thumbnails using the command listFiles works for Z1 and V, but does not for the SC2. The command will show a default list of 10 and can be set to show any number for totalEntries. This does not work for the SC2. Only 1 thumbnail is displayed.
The command is found here in the RICOH API documentation: https://api.ricoh/docs/theta-web-api-v2.1/commands/camera.list_files/
Workaround
There is a workaround. It is possible to loop through the list of files on the camera to manage the thumbnails.
The sequence of actions is:
Create http client object
Open http connection to camera
Grab each thumbnail individually, once per loop
Add bytes of thumbnail into array each time through the loop
Close http connection
Return array
Example code snippet:
try {
// loop through list of urls
for (var i = 0; i < urls.length; i++) {
var response =
await client.get('${urls[i]}?type=thumb', headers: headers);
print(response.statusCode);
print('loading file ${i + 1}');
thumbs.add(response.bodyBytes);
Test Environment
SC2
“firmwareVersion”: “01.64”
Test Procedure
Run opptheta with the following commands
Use
infoto confirm firmware versiondart opptheta.dart info -
Use
listFilesto see a listing of images on the camera. It will show 10 total. The listing “_thumbSize” will show that thumbnails exist, but it will not show any data. Even though the output shows 10 entries, at the end of the output, it will show totalEntries, indicating how many pictures are on the SC2.dart opptheta.dart listFiles -
Add
--maxThumbSize=640to show thumbnails. It will only show binary data on the command line. (Add --maxThumbSize=0 if you want to explicitly exclude thumbnail data.)dart opptheta.dart listFiles --maxThumbSize=640
More Information
If you’d like a detailed description with code examples, please go to https://theta360.guide/special/sc2/ and by entering your email address, you will have access to a wide range of SC2 articles and videos. Under the list of Articles, grab “Getting thumbnails from the RICOH THETA SC2” (PDF).
Video tutorial: Comparing listFiles Thumbnail Command for RICOH THETA Z1, V and SC2
opptheta command line tool available here: https://github.com/Oppkey/oppkey_theta_atk/releases/tag/v0.2.0-alpha
