I’m using the Ricoh Theta Sticher to stitch DNG files from the Theta Z1. I have tried files from the Theta app and the DualFishEye plugin however on all instances, if I try to update the ‘Stiching method’ or ‘Camera Visibility Reduction’ settings, I receive a “The images could not be processed successfully 0x00000001”, the image then goes black. I am able to change ‘Zenith correction’ and ‘Front position adjustment’.
I am able to stitch the image if I leave the settings as default however it seems all the images aren’t stitched correctly which is why I need to change the stitching method.
I am using a Ryzen 3700x, 1070ti and 16gb RAM.
I have also tried this on my laptop which has a i5 8250u, MX150 and 16gb RAM.
Can anyone shed some light on this? I’ve not found any mention of this issue elsewhere in the forum it seems
