Hello again @craig sorry for not being precise.
Here is what I want as a final output : I want to build a DL model where each sample is 2 camera 360° images(I am using two Ricoh Theta V) and a LiDAR output as a groundtruth.
So each sample ( : two images) and groudtruth output should be time sync.
Thus, the most important is to have the triplet output sync for my model, it does not matter if it is done in real time or if I find a way to do it in post-processing.
At the moment I used ROS synchronizer (and open cv while cameras are in streaming mode) to sync them in Real time (by taking the bottelneck frame rate : LiDAR that has 10 fps and whenever a LiDAR frame comes I take the two closest camera images).
For now my synchronized timestamp looks like this :
Even though it seems sync, there is a problem and time difference between the two camera frames (which are approximatively well sync) and the LiDAR because of this (I am synchronizing with the date of the data arrival at the disk and not the real capturing date):
So now I am stuck at this level, and was wondering if there is a simpler way to sync them in post processing (post recording way) as there is no need in my case to sync them in real time.
PS : I am using a jetson AGX Xavier, a LiDAR Ouster OS1, two Ricoh Theta V for this project.
Thank you very much for the help
