Speech detection, object detection, stylized filters, deep learning classification all working inside the THETA V. Download pre-compiled Tensorflow apk for developers or power users with developer mode enabled.
Wow, this is cool! I mean, SERIOUSLY cool! I grabbed the apk that @codetricity built and installed it in my THETA V. Very smooth. For once, I remembered to set the permissions properly (only need to do that once, the first time it’s installed) and was able to run the plug-in from Vysor very easily. Here’s screenshots from two of the four functions.
Apparently Tensorflow has 95% certainty that I’m a person. I feel good about this.
I could probably spend some time playing with this! There appear to be at least 26 filters included in the plug-in by default.
Fantastic. Thanks for posting.
I think it would be useful to show more examples of use. Consider making a video of your tests with TensorFlow.
The background research for the artistic styles is found in this paper.
This image shows you the basic idea for the artistic style training.
I added more information on how to download the TF Stylize images from the RICOH THETA V.
One of the problems with equirectangular images is that a standard object dataset like COCO (Common Objects in Context) doesn’t play well with objects on the edge.
This paper talks about using COCO with YOLO.
Their solution is to use four sub-windows.
As this is a research paper, it seems unlikely we’ll be able to solve the problem with the THETA V to get full 360 object detection. We may be able to a reasonable 210 degrees of detection without too much work. I’m curious to learn how other people have progressed.
