I`m using theta camera with react native, in ios its working perfectly but in android its connected but not stable its giving me white screen and then connect its continue doing this
Use the live preview example in this demo:
Compare the delta on this commit which fixed the problem.
worked with me thank u very much @craig,
Can you output the URL to the debug console, then copy and paste the URL into a web browser?
The URL of the image should be the same as a standard network image.
Is there any error in the debug console when you attempt to display the image?
