Flutter
theta-client 1.12
Running flutter pub add theta_client_flutter will not work from a new app. You need to copy the contents of theta-client/flutter into your_project/packages/theta_client_flutter
install theta_client_flutter into a new application
- clone down theta-client from GitHub at https://github.com/ricohapi/theta-client
- in a separate folder, start a new flutter project
flutter create --platforms=ios,android my_flutter_project mkdir my_flutter_project/packagesmkdir my_flutter_project/packages/theta_client_fluttercp -r theta-client/flutter/* my_flutter_project/packages/theta_client_flutter/- add the path of the locally-installed
theta_client_flutterpackage to yourmy_flutter_project/pubspec.yamlfile flutter pub get
This is the relevant portion of pubspec.yaml. Note that the dependency is specified with path: ./packages/theta_client_flutter
dependencies:
flutter:
sdk: flutter
theta_client_flutter:
In addition, upgrade the minimum version of iOS in project_root/ios/Podfile.
platform :ios, '16.0'
In ios/Flutter/AppFrameworkInfo.plist I added this key.
<key>MinimumOSVersion</key>
<string>16.0</string>
iOS
For iOS builds, including Flutter and React Native for iOS, theta-client is distributed as a pod.
Make sure you update the cocoapod repos.
pod repo update
You can check if your system can find the latest pod with
pod search THETAClient --simple
-> THETAClient (1.12.0)
THETA Client
pod 'THETAClient', '~> 1.12.0'
- Homepage: https://github.com/ricohapi/theta-client
- Source:
https://github.com/ricohapi/theta-client/releases/download/1.12.0/THETAClient.xcframework.zip
- Versions: 1.12.0, 1.11.1, 1.11.0, 1.10.2, 1.10.1, 1.10.0, 1.9.1, 1.9.0,
1.8.0, 1.7.1, 1.7.0, 1.6.0, 1.5.0, 1.4.0, 1.3.1, 1.3.0, 1.2.0, 1.1.0, 1.0.0
[trunk repo]
(END)
