What’s more than in this screen shot?
That’s an interesting idea about the mounting connector being metal and adding to the heat dissipation through some type of static heat radiator.
Many years ago, there was a modification to the RICOH THETA S for improved heat dissipation for cooling.
From Dec 2015
Dec 2015
This eventually became a production camera.
Here’s more of a test.
That’s an interesting idea to use the bottom of the camera as a heat sink thermal pad that can be attached to a air-cooled radiator using the tripod screw mount as the attachment point.
The Labpano One EE has a metal housing, but suffering from overheating still, so they provided a cooling rod along with it.
I am not that original ![]()
Actually, I do not get why these manufacturers produce cameras that have a max operating temperature of 45 C only. For whatever video use in full summertime sun, one reaches 50 C easily. Here on Curaçao it is summertime or sauna time always. It reveals they have no clue about practical application of their products although they promote them for outside professional work.
