flutter recommend panorama panorama | Flutter Package
@shougongyiren , thanks for this nice tip.
I used your technique in this test.
We awarded you the Community Thanks Award for this tip.
The award comes with a small cash award that you can use to grab a drink on us. ![]()
please are you taking the pictures with the RICOH camera or with that of the phone .
i will realy like to implement mine but , i whant each user to be able to take a panoramic image with his phone , it is posible ?
Most Android phones have the ability to take multiple images and then stitch the images together into a single panorama. It will take time to take all the images. iPhones can probably do the same thing.
A specialized 360 camera like the RICOH THETA will give a better-quality stitch.
Ok I see, thanks for the response, I will further into RICHO camera then, for my app
what type of app are you thinking of building? Is it to help sell real estate or document construction sites?
If the app is for a business use, then it’s going to be faster if you use a 360 camera and the stitching will be better.
If it is for a hobby, than the mobile phone will work.
If you plan to put it on top of a robot and get the live stream from the robot, you may want to stream over the USB cable. Only the V, X, Z1 can stream over the USB cable.
