This topic is to discuss Michael Li’s Wildlife Transect Motion Monitor plug-in for the RICOH THETA V.
Available in THETA Plug-in Store
In scientific studies of the environment, transects are placed in areas such as forests. In each transect, sensors such as temperature are placed that record data to either a local device or a connected data. As the transects are often remote, we collect visual data.
This plug-in triggers a picture when there is high wind in the area of the transect which could disrupt the sensors.
Picture will trigger once THETA is moved by either pitch or roll by a threshold. Currently set to +/- 0.8.
Example Mounting
- Attach camera mount to end of 2 meter fiberglass rod. Inexpensive bicycle flag poles can be used.
- Mount is a 1/4" by 20tpi threaded bolt and can be tied to the fiberglass rod and secured with epoxy.
- Use extension to enable THETA to be powered by USB cable
- Thread styrofoam block through the rod and place it under the camera. The styrofoam block catches the wind.
