I have a question about 360 videos files. What I want to do with the 360 video, is copy them straight to my laptop and play them in the windows player. But then it looks really weird:
Is there a video player / software that is able to do this right away? or do you need fix these with bottom and top correction. Work alot with actors and want to plug the THETA V to a laptop copy the files and check the quality of the recording as fast as possible.
I was wondering if there is any software / player / setting to use it right away? Or be able to view it a little bit better then in the windows player?
VLC does not show it great without the stitching
The default setting is for the video to be recorded as dual-fisheye. You can use the mobile app from RICOH to set the camera to automatically stitch the videos internal to the camera and thus saved as equirectangular. Once you set the stitching, you can turn off or reboot the camera and the settings will be saved. You only need to set the stitching once.
