When we try the getvatterylevel api, this is the response we get. Earlier it used to show this error sometimes but now it has become regular, this api does not return any response at all. This is for the Z1 with ios. We tried using an api tester app as well as the ricoh theta demo app, but everything responds in the same way, not able to get a response from the getbatterylevel api
*GetBatteryLevel Error:*
*Endpoint: /osc/state*
[array valueForKey:@"state"]
[state valueForKey:@"batteryLevel"]
Error Domain=NSURLErrorDomain Code=-1004 "Could not connect to the server." UserInfo={_kCFStreamErrorCodeKey=61, NSUnderlyingError=0x1511f79c0 {Error Domain=kCFErrorDomainCFNetwork Code=-1004 "(null)" UserInfo={_NSURLErrorNWPathKey=satisfied (Path is satisfied), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=61, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <1CEE17B4-B60B-44A3-9217-D8A58035DE41>.<29>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
"LocalDataTask <1CEE17B4-B60B-44A3-9217-D8A58035DE41>.<29>"
), NSLocalizedDescription=Could not connect to the server., NSErrorFailingURLStringKey=https://192.168.1.1:443/, NSErrorFailingURLKey=https://192.168.1.1:443/, _kCFStreamErrorDomainKey=1}
*GetDeviceInfo Error:*
*Endpoint: /osc/info*
Error Domain=NSURLErrorDomain Code=-1004 "Could not connect to the server." UserInfo={_kCFStreamErrorCodeKey=61, NSUnderlyingError=0x1511f5170 {Error Domain=kCFErrorDomainCFNetwork Code=-1004 "(null)" UserInfo={_NSURLErrorNWPathKey=satisfied (Path is satisfied), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=61, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <20AB6766-59E9-4D43-8C8C-90EBB60C758F>.<41>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
"LocalDataTask <20AB6766-59E9-4D43-8C8C-90EBB60C758F>.<41>"
