trying to reduce the ImageSize for image capture mode for faster captures
ptpcam --show-all-properties
Camera: RICOH THETA SC2
0x5001: 100
0x5002: 0
0x5003: "5376x2688"
according to documentation here Image_size
I believe a smaller image size of 2048x1024 is also supported,
but my attempts to change the property via ptpcam does not work
'Image Size' is set to: "5376x2688"
Changing property value to 2048x1024 [(null)] FAILED!!!
PTP: Invalid Device Prop Value
❯ ptpcam --set-property=0x5003 --val="2048x1024"
❯ ptpcam --set-property=0x5003 --val='"2048x1024"'
Changing property value to "2048x1024" [(null)] FAILED!!!
gphoto2/gphoto2 --list-all-config
/main/other/5003
Label: Image Size
Readonly: 0
Type: MENU
Current: 5376x2688
Choice: 0 5376x2688
END
gphoto2 seems to disagree with the usb api documentation. is the documentation wrong?
firmware version: 1.64
