Just adding this information here because I was unclear of the difference between the two shooting methods Continuous Shooting and Interval Shooting. This is what I understand:
From RICOH documentation:
Continuous Shooting - Continuous shooting is only available on X. When the image resolution is set to 11K, 8 images are shot right in a row, and when it is set to 5.5K, 20 images are shot in 2 seconds (exact timing may vary).
Interval Shooting - Interval shooting is available on THETA X and previous models. You can set the shooting interval (from 6 seconds to 60 minutes, in 1-second increments) and the number of shots (from 2 to 200 images, or Not specified) as desired.
In the API
camera.startCapture in the API shows shooting methods and has a table with which models support which methods.
| Shooting mode | X | Z1 | V | SC | S |
| Interval shooting | All | All | All | All | v01.62 or later |
| Multi bracket shooting | All | All | All | v1.10 or later | v01.82 or later |
| Interval composite shooting | — | All | — | v1.10 or later | v01.82 or later |
| Time shift shooting | All | All | v3.00.1 or later | — | — |
| Movie shooting | All | All | All | All | v01.62 or later |
| Interval shooting (optimized *1, Tripod stabilization Off) | — | v1.50.1 or later | v3.40.1 or later | — | — |
| Interval shooting (optimized *1, Tripod stabilization On) | — | v1.50.1 or later | v3.40.1 or later | — | — |
| Burst shooting | — | v2.10.1 or later | — | — | — |
| Continuous shooting | All | — | — | — | — |
*1 Top/bottom correction and stitching conditions are optimized.
