Firmware and Mobile App Upgrades - Z1:1.50, V:3.40.1
Official note from RICOH.
Newest firmwares:
  • Z1 - 1.50
  • V 3.40.1
Mobile App
  • Top/bottom correction optimization for interval shooting. Select tripod stabilization as off
THETA+
Horizon animation pre-set
Mobile App Upgrade Process
Test with Pixel 2 running Android 10.
Firmware Upgrade Process
To connect the camera and mobile app, I needed to stop the mobile app and restart it while the camera was still connected with Wi-Fi. The mobile data on my Android phone is off.
At this point,
  • connect mobile phone to my Wi-Fi router for Internet access.
  • Go back to mobile app.
  • Mobile app is no longer connected to Z1.
  • reconnect to Z1
  • camera red light flashes
  • camera reboots
  • flashes “Firmware Update”
  • camera is now disconnected from the mobile phone
THETA V Firmware Upgrade Test
This went on for a while.
Stopped app
Immediately comes up after I restart the app. Not sure why.
I have bluetooth, mobile data, and battery saver all turned off.
Connect back to Internet.
V firmware needs to be updated from 3.30.1 to 3.40.1
Need to charge camera.
Will continue after it charges.
Upgraded my THETA Z1 firmware using the Windows 10 RICOH THETA desktop app. Upgraded from 1.20.1 to 1.50.1 smoothly. Total time was about 5 minutes.
When you start the firmware process, it shows Current Version and Newest Version:
Download and installed over my home network took about 3 minutes:
Camera shows a blinking “Firmware Update” on the OLED and reboots when finished.
Quick check of current version:
@jcasman, when you upgraded with the desktop software, did you notice any message about turning off the camera manually? Someone was asking about that. I wonder if they misunderstood that the camera is supposed to reboot automatically?
I did not see any message about turning off the camera manually. The OLED shows the Firmware Update message blinking for maybe 1 minute and then it reboots without any action on my part. This is the same sequence as when I’ve upgraded firmware in the past.
