Im trying to see if its possible change exposure and white balance while live streaming. When Im connected to the device with WiFI - I can’t switch into live streaming mode. I can’t seem to connect to it via bluetooth. Anyone know if it is possible?
To my knowledge, no, you cannot adjust the settings while live but you can choose the settings you want before you go live. You will connect via Wifi to the app and see which settings you like best and then under settings in the app click on “my camera settings” and there should be a send option and it will send those settings to the camera. I use the Ricoh Theta S model.
