Hi
I’ve read a lot of posts on getting things done using jetson card + Ricoh Theta cam. I’m still facing the same issues…
that one
and that one
and others :-/
First, my material :
- Jetson Xavier AGX (I get the same error using Jetson xavier NX)
- I use the Ricoh Theta Z1.
I followed the guide : RICOH THETA Development on Linux
I’ve installed
libuvc-theta → ok
libuvc-theta-sample
I change the line (related to gst_loopback) of gst_viewer.c to
pipe_proc = “nvv4l2decoder ! autovideoconvert !”
“video/x-raw,format=I420 ! identity drop-allocation=true !”
“nv3dsink device=/dev/video0 sync=false”;
./gst_viewer is running and I see the stream
./gst_loopback is running and I also see the video stream
./gst_loopback
Opening in BLOCKING MODE
start, hit any key to stop
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
I’ve successfully installed the module v4l2loopback
~/ricoh/libuvc-theta-sample/gst$ lsmod
Module Size Used by
v4l2loopback 42831 0
when I run cvlc … I got a seg fault error …
ricoh/libuvc-theta-sample/gst$ cvlc v4l2:///dev/video0
VLC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
[000000557ba0cfd0] dummy interface: using the dummy interface module…
Segmentation fault (core dumped)
when I run v4l2-ctl --list-formats I do not see the camera
~/ricoh/libuvc-theta-sample/gst$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
gst-launcher does not work neither…
~/ricoh/libuvc-theta-sample/gst$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,framerate=30/1 ! xvimagesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
DOes someone could help me with that?
Thanks…
