Greetings to all. I have a problem. I have THETU SC. I can’t charge, I tried the original cable, non-original cables, charging from a PC, but also from the wall. He doesn’t react at all. The only thing he reacts with is POWERBANK. It flashes red, you can also take a picture of the trigger. As soon as I disconnect from POWERBANK, it switches off. I tried to change the battery, but it behaves exactly the same. Does anyone have a tip on how to do this?
Related topics
| Topic | Replies | Views | Activity | |
| Theta SC will not charge or connect | 1 | 911 | February 12, 2019 | |
| Ricoh Theta S is not charging. I have even replaced the battery | 0 | 70 | September 24, 2025 | |
| Charging and turning on issues | 0 | 483 | December 4, 2020 | |
| Problems Charging the THETA | 7 | 8783 | February 13, 2017 | |
| Can't start Ricoh Theta V, red light | 2 | 1904 | July 30, 2020 |
