Theta SC will not charge or connect
Theta SC will not charge up,
when connecting charge cable the green charge light flashes once then nothing else.
I have tried different cables, car charger, laptop and mains connection but all the same outcome.
I have tried to connect to the Theta app to update firmware but pc doesn’t detect the camera.
Have tried to do a test by holding the power key down for 8 sec but not result.
Would be good to have a solution to fix this issue.
Thanks
If you just bought the camera, you should call RICOH customer support or the store you bought the camera at. You may have a problem with the USB connector on your camera.
