Originally published at: RICOH THETA Z1 Technical Specifications – RICOH THETA Developer Community
RICOH THETA Z1 51GB / RICOH THETA Z1
- 1″ image sensor
- Qualcomm Snapdragon 625, MSM8953_64
Android OS 7.1.2
Supported APIs
- Web API v2.1
- RICOH THETA Plug-in API
- Note that the WebAPI can be accessed from inside of the plug-in in addition to the Android Camera API.
- RICOH THETA BLE API (Bluetooth)
CPU and Snapdragon 625 Specifications
- ARM Cortex A53 CPU, 1.8 GHz, 64bit
- Bluetooth Specification Version: Bluetooth 4.1
- Wi-Fi Spectral Bands: 2.4 GHz, 5 GHz
- USB Version: USB 3.0
- GPU Name: Qualcomm® Adreno™ 506 GPU, OpenGL® ES 3.1+
LSM6DSM Accelerometer from STM.
General Specifications
- Release date RICOH THETA Z1 51GB:5/2021
RICOH THETA Z1:5/2019 - Exterior/external dimensions 48mm (W) × 132.5mm (H) × 29.7mm (24mm*9) (D)
- Weight] Approx. 182 g
- Still image resolution 6720×3360
- Video resolution/frame rate/bit rate 4K 3840×1920/29.97fps/56Mbps
2K 1920×960/29.97fps/16Mbps - Live streaming resolution/frame rate (USB) 4K,H264: 3840×1920/29.97fps/120Mbps
2K,H264: 1920×960/29.97fps/42Mbps - Microphone 4ch
- Internal memory/Number of photos that can be recorded, time *2 RICOH THETA Z1 51GB:
Approx. 51GB
Still image: RAW+ Approx. 900 photos, JPEG Approx. 6350 photos
Video (time per recording): Max. 5 minutes/25 minutes*3*4
Video (total recording time): (4K, H.264) approx. 110 minutes
(2K, H.264) approx. 360 minutesRICOH THETA Z1:
Approx. 19GB
Still image: RAW+ Approx. 350 photos, JPEG Approx. 2400 photos
Video (total recording time): (4K, H.264) approx. 40 minutes
(2K, H.264) approx. 130 minutes - Compatible accessories Tripod/stand (includes tripod mount hole)
- Bundled items Soft case and USB cable
- Object distance Approx. 40cm – ∞ (from front of lens)
- Shooting mode Still image/video: Auto, Aperture priority, Shutter priority, ISO priority, Manual*3
Live streaming: Auto - Exposure control mode Program AE, Aperture priority AE, Shutter priority AE, ISO priority AE, Manual
- Exposure compensation Still image/Video: Manual compensation(-2.0 to +2.0 EV, 1/3 EV steps)*3
- ISO sensitivity (standard output sensitivity) Still image/video: (Auto) ISO 80 to 6400
(Can set upper limit) ISO 200 to 6400
(Manual mode) ISO 80 to 6400 *3
Live streaming: ISO 80 to 6400 - White balance mode Still image/Video: Auto, Outdoor, Shade, Cloudy, Incandescent light 1, Incandescent light 2, Daylight color fluorescent light, Natural white fluorescent light, White fluorescent light, Light bulb color fluorescent light, Color temperature settings (2500 to 10000 K)*3
Live streaming: Auto - Shutter speed Still image: (Auto) 1/25000 to 1/8 seconds,
(shutter priority mode) 1/25000 to 15 seconds *1
(Manual mode) 1/25000 to 60 seconds *1
Video: (Auto) 1/25000 to 1/30 seconds
(Shutter priority, Manual) 1/25000 to 1/30 seconds*3
Live streaming: (Auto) 1/25000 to 1/30 seconds - Shooting functions Still image: Noise reduction, DR compensation, HDR rendering, Handheld HDR, Interval shooting, Interval composite shooting, Multi-bracketing shooting, Self-timer (2 to 10 seconds), My Settings
Video: Self-timer (2 to 10 seconds), My Settings - Power source Lithium ion battery (built-in) *7
- Battery life Still image: Approx. 300 photos *8
Video: Approx. 60 minutes *8 - Recording file format Still image: RAW(DNG)*2, JPEG(Exif Ver2.3)
Video: MP4 (Image: MPEG-4 AVC/H.264, Audio: AAC-LC (mono) + Linear PCM (4ch spatial audio))
Live streaming: Image: H.264, Audio: Linear PCM(4ch) - External interface USB Type-C:USB3.0
- Remote release CA-3-compatible
- Lens configuration 14 elements in 10 groups
- Lens_F value F2.1, 3.5, 5.6
- Image sensor_size 1.0-inch type (x2)
- Effective pixels] Approx. 20 megapixels (x2)
- Output pixels approx. 23 megapixels
- Wireless compliance standard IEEE802.11 a/b/g/n/ac (2.4GHz/5GHz)*5
IEEE802.11 b/g/n (2.4GHz only)
Bluetooth 4.2 - Wireless supported channels 2.4 GHz: 1 to 11ch or 1 to 13ch *6
5 GHz: W52 (36 to 48ch, channel bandwidth 20/40/80 MHz supported) *5 - Wireless communication protocol (WLAN) HTTP (Open Spherical Camera API v2 compatible)
- Wireless communication protocol (Bluetooth) GATT(Generic Attribute Profile)
- Usage temperature range 0°C – 40°C
- Usage humidity range 90% or less
- Storage temperature range -20°C – 60°C
*1 The number of photos and time are guides only. The actual number differs according to the photography conditions.
*2 Only possible for simultaneous recording of RAW and JPEG.
*3 A smartphone is required to change modes or configure manual settings.
*4 Automatic shut down if the internal temperature increases.
*5 RICOH THETA Z1 OTHER COUNTORIES(L85612/EDP CODE: 910776 /RIM CODE: S0910776/JAN CODE: 4961311935442/UPC CODE: 026649107771) does not support 5GHz
*6 RICOH THETA Z1 US (L85614/EDP CODE: 910778 /RIM CODE: S0910778/JAN CODE: 4961311935466/UPC CODE: 026649107788) RICOH THETA Z1 TWN (L85613/EDP CODE: 910777 /RIM CODE: S0910777/JAN CODE: 4961311935459/UPC CODE: 026649107771) supports 1 to 11ch.
*7 Charge the battery by connecting it to a PC using the supplied USB cable.
*8 The number of photos that can be taken is a guide based on RICOH’s measurement method. This will differ depending on the usage conditions.
*9 Excluding lens section.
■Specifications and the design may change without prior notice.
■Specifications are current as of February 2019.
