Ok, I will try to keep my PC on for a very looong time…Hope it works. No Icon on the PC because the camera is turned off. Thanks
Hopefully, it will work. However, the CLBT likely means that there was a problem with the firmware upgrade by a previous owner. Unfortunately, there may be an unrecoverable error. Let’s hope for the best.
Thanks, so this second hand camera has a firmware error, i thought that message could mean it needs a firmware update instead. Do you tnink that a reset could solve the problem? Well I need to charge it first, if’s still connected to the pc usb port and green light keeps blinking… I will see tomorrow morning Thanks for your help. Regards
If you update the firmware on the camera, it may solve the problem.
Hi, sorry I know I’m annoying you but can You explain me this picture I attach ? Where to find drivers for this camera ? Thanks
You don’t need special drivers.
You can install the desktop software for the PC.
However, I do not think the desktop application installs any special driver.
The app is waiting for something. It could be data transmission.
Unfortunately, it may mean that the camera to computer communication may have a problem. This might be due to the firmware corruption.
Oh… Undetdtood, I will return the camera back to the seller, thanks for your help. Thanks
If it were my camera, I would return it. Likely, the previous owner had a problem during the firmware upgrade of the camera and the OS on the camera is corrupted. If you plugged it into the computer for a long time and the camera still can’t boot, I can’t think of anything else you can do.
Hello, Thanks for your help, but is there a list of smartphones that work with ricoh theta sc2 ? I have an Armor X 7, android 10, with 5G wifi , could It work with theta sc2 ?
Thanks
There is no official list of supported phones.
personally, I use an old Pixel 2 running Android 10. Some people have problems with connection, though I can’t replicate the connection problems. If you have a Facebook account, you may want to try post to a group and see if other people have the same phone.
You will not be able to use 5G to the Internet and Wi-Fi to the camera at the same time.
