When trying to build demo-react-native on iOS, encountered str.replace is not a function
yarn run ios
**yarn run v1.22.22**
$ react-native run-ios
**error** str.replace is not a function.
TypeError: str.replace is not a function
at inlineString (/Users/craig/Development/ricoh/2024/theta-client/demos/demo-react-native/node_modules/@react-native-community/cli-tools/build/errors.js:25:33)
I successfully used this solution on Stackoverflow.
I had to log into to apple.com again. Per the tip, I reselected Command Line Tools: Xcode 16.
I got further and encountered this error:
{ platform:iOS, id:dvtdevice-DVTiPhonePlaceholder-iphoneos:placeholder, name:Any iOS Device, error:iOS 18.0 is not installed. To use with Xcode, first download and install the platform }
Installed iOS simulator 18
build still failing.
Tried pod install from ios directory. Failed
building theta-client.
theta-client % ./gradlew podPublishXCFramework
update pod repo and try pod install again
pod repo update
Updating spec repo `trunk`
craig@Craigs-MacBook-Air demo-ios % pod install
Analyzing dependencies
Downloading dependencies
Installing THETAClient 1.10.2 (was 1.10.0)
Generating Pods project
Integrating client project
Pod installation complete! There is 1 dependency from the Podfile and 1 total pod installed.
getting error about cmake
WARNING:C/C++: Could not execute cmake at '/Users/craig/brew/opt' to get version. Skipping.
though, cmake exists in brew/bin/cmake
trying brew update and brew upgrade
now finding cmake, but build still failing
disable flipper
in ios/Podfile disable flipper
it works
**info** Installing "**/Users/craig/Library/Developer/Xcode/DerivedData/DemoReactNative-gfpzbpthmvykvpavmbxdqvulctno/Build/Products/Debug-iphonesimulator/DemoReactNative.app** on iPhone 16 Pro"
**info** Launching "**com.ricoh.thetaeditor.--PRODUCT-NAME-rfc1034identifier-**"
**success** Successfully launched the app on the simulator
✨ Done in 51.78s.
