Theta-client (official SDK) v1.2 released with client mode, time-shift, previewFormat and more
theta-client is RICOH’s official SDK for the RICOH THETA camera line. It works with X, Z1, SC2, and V. The SDK is open source and works with iOS native, Android native, React Native and Flutter.
New features include:
  • time-shift
  • wireless LAN client mode
  • THETA X external memory card support
  • THETA X power saving and LCD screen control on/off support
  • control of preview format, shutter speed and WLAN frequency (2.4 or 5GHz) on Z, Z1, V
Eval Walkthrough for Android Demo Build
git clone https://github.com/ricohapi/theta-client.git
cd theta-client/
git checkout 1.2.0
git switch -c 1.2.0
./gradlew publishToMavenLocal
BUILD SUCCESSFUL in 46s
Using Android Studio Flamingo on Ubuntu 22.04
with RICOH THETA connected to workstation with WiFi.
Tip: Use two network interfaces
Flutter Build
The theta-client library works with different platforms (Android native, iOS native, React Native, Flutter). I’ll also test the Flutter demo using Flutter 3.10.5.
cd demo-flutter
flutter pub get
flutter run
screen_flutter
Testing new features
The short code snippets illustrate the use of dart enums to get the values of the new options. This is quite nice with the auto-completion of most editors. For example, in VSCode, I can see the available options for WLAN frequence with the . dot after the enum name.
You can also see all the options available in your code editor. This reduces errors for incorrect values and mismatched types.
To test the new theta-client features, I created a button on the demo screen.
Test for preview format, shutter speed
These are the three new options common across V, X, Z1
  TextButton(
      onPressed: () async {
        if (isInitialized) {
          debugPrint('THETA: theta is initialized');
          final options = await thetaClientFlutter.getOptions([
            OptionNameEnum.previewFormat,
            OptionNameEnum.shutterSpeed,
            OptionNameEnum.wlanFrequency,
          debugPrint('THETA width: ${options.previewFormat}');
          debugPrint(
              'THETA shutter speed: ${options.shutterSpeed}');
          debugPrint(
              'THETA WLAN Frequency: ${options.wlanFrequency}');
Output
I/flutter (12041): THETA width: W1024_H512_F30
I/flutter (12041): THETA shutter speed: SHUTTER_SPEED_AUTO
I/flutter (12041): THETA WLAN Frequency: GHZ_2_4
THETA X specific: camera control source, camera mode, power saving
TextButton(
          OptionNameEnum.cameraControlSource,
          OptionNameEnum.cameraMode,
          OptionNameEnum.powerSaving,
        debugPrint(
            'THETA X - camera control source: ${options.cameraControlSource}');
        debugPrint(
            'THETA X - camera mode: ${options.cameraMode}');
        debugPrint(
            'THETA X - power saving: ${options.powerSaving}');
    child: const Text('check options')),
Output
I/flutter (12041): THETA X - camera control source: CAMERA
I/flutter (12041): THETA X - camera mode: CAPTURE
I/flutter (12041): THETA X - power saving: ON
Example using option in conditional check
WlanFrequencyEnum is an enum built into theta-client.
  if (options.wlanFrequency == WlanFrequencyEnum.ghz_5) {
    debugPrint('wlan is at 5GHz');
  } else {
    debugPrint('wlan is not at 5GHz');
      WlanFrequencyEnum.ghz_2_4) {
    debugPrint('wlan is at 2.4GHz');
  } else {
    debugPrint('wlan is not at 2.4GHz');
Output
I/flutter (12041): wlan is at 5GHz
I/flutter (12041): wlan is not at 2.4GHz
full list of changes
Assets 3
37.7 MB
Release 1.2.0 · ricohapi/theta-client
Hey, I’m working on the React Native version testing of v1.2 of Theta-client. I’ve found all the available Enums in this file. Currently getOptions only works for me to show up in the console, and I can’t get it to show up in a returned text component. I suspect that it has something to do with the way javascript promise returns work.
I haven’t looked too closely at the demo-react-native project. For Flutter, I had to wait for thetaClientFlutter.getOptions() to complete.
There may be a async/io problem with getting the text to appear on the React Native screen.
What are you using to manage state and update the screen? Are you using a react hook?
