Hi!
Yesterday I bought a Theta V so I can livestream in 360. I have read the manual, followed the steps, installed the drivers but I couldn’t make the camera work until I installed the old drivers.
First I installed the “Version 2” driver of the June 2020 update, and OBS showed “status 0x80004005” error, and DirectShow error. No video signal on MPC-HC and VirtualDub too.
Then, I deleted this driver, and installed the driver Win 64 of 10/13/2017 Update, and finally OBS showed the video. But I know this is not the best or optimized driver, what can I do?
Info
Windows 10, ver.1909
Theta V, firmware 2.50.1
Drivers from: Here
The old driver and the new driver have the same video quality. However, the new driver will have lower CPU usage and possibly heat. The heat and CPU usage reduction might be important in your usage, on a laptop.
If you need the new driver (for heat or CPU usage reasons), have you tried the following:
reboot after installing the driver
on OBS, toggle the video device to your built-in webcam first and then to the THETA driver. Try this a few times
