Hi I just tried the USB Data Transfer Plugin to a OTG Flash Drive and its flashes Red, Beeps then turns off
but the overs plugins work like Remote playback plugin.
Mitsuperboy
Mitsuperboy
I’ve had this issue before. I had to reformat my OTG flash drive and then it worked. Give that a go.
what kind of file system you choose. Mine is not working neither. I have tried NTFS , FAT32 , exFAT. None of them worked
I use RICOH THETA Z1
The drive I use is formatted as FAT32. It is kind of pokey solution and can be frustrating. Do you have a an iOS device? iPhone or iPad? That might be an easier option using the Apple USB 3 Camera adapter.
Thanks! I got your idea. I just want to get my USB Data Transfer plugin to work so that I can backup on the go without tablet or adapters
I can’t find the USB Data Transfer Plug-in on the THETA Store.
Does anyone know what happened to it?
