Prezados bom dia. Sei que existe um acessório disparador via cabo USB para a Theta S, mas o produto é caro e difícil de obter por aqui (Brasil), haveria uma forma de construir esse disparador ? Alguém sabe como é o circuito elétrico desse acessório ?
Grato
Editor’s update using Google Translate machine translation
Dears, good morning. I know there is a USB cable trigger accessory for Theta S, but the product is expensive and hard to get here (Brazil), would there be a way to build this trigger? Does anyone know what the electrical circuit of this accessory is?
Grateful
@Sergio_Ravara_Barra1 Please write in English
we have over 250 meters connection reach via WiFi and never had to use a cable
the self timer works as well
I understand, but when I use a pole stick or I want to look at the camera to make a video without having to look or run the app via mobile would be easier. I’m talking about the accessory available at https://theta360.com/en/about/theta/accessory.html the CA-3 cable switch
Cable switch
CA-3
This is a cable switch to operate the camera shutter.
Supported models Compatible models: RICOH THETA V, S, SC
Please insert the USB cable bundled with the purchased camera. An AAA battery is required to purchase separately.
Half-press shutter function is not applicable.
When you mount RICOH THETA on a tripod or some other accessory, it may interfere with the cable that you insert into the terminal on the camera. If that happens, we recommend that you use the TE-1 Extension Adapter.
Pi Zero W using internal wifi to connect to the Theta S plus a second external WIFI access point is used to allow connection to the Pi Theta webpage and for SSH connections to the Pi.
One good upgrade
to the THETA hardware were a small micro pin shutter conection in the bottom of the camera for connection of a Selfie stick with shutter button
all right
This is not a new invention but are in use on other Camera brands like the Madv360 as i call it
it is rather Handy to have the camera connected to the Phone in the pocket via Wifi and shoot the images with the Selfie stick
The GPS info are then transferred from the phone and tagged
in the image file in the camera
the camera takes a full360 degree image so a preview are not always necessary
keeping the selfie stick above the head vertical makes it easy to patch the nadir and remove the Photographer on the final image
furthermore when shooting in horizontal view
the person shooting looks more pleasant on the image
than a guy standing starring on his iPhone
Regards Svendus
