I have a research project going on that envolves capturing roads with the Theta V for Spherical Photogrammetry processing for generating point clouds. For better results in this processing software, ideally we want the highest resolution possible. I found a topic mentioning this once but I would like to confirm if it really is possible to lower the frame rates and record a video with a higher resolution and if it is possible, how should I approach it in order to make it happen?
