Please post your settings screen:
Source: Ikoma360
Can you put the DNG file up on a location like Google Drive or DropBox and then put the link to the DNG file in this forum? Maybe someone can go through the steps and test it.
Your lightroom and windows version meets the requirements, right?
https://support.theta360.com/en/enviroment/#LRSTITCH
Adobe Lightroom Classic CC v8 or higher and Windowws 10 64 bit 1607 or higher?
Here is a link to DNG hdr file.
Both Windows and Lightroom meet the requirements. But I am not sure about GPU. I have NVIDIA NVS 310 and can not find if it is compatible with OpenGL 4.1 or higher
Hi, Andrew.
I’ve reproduced your issue on my computer. It’s an error of Photo merge/HDR. See the screenshot as below.
And I’d like to highly recommned you to try on #SingleDNG. It’s faster and more comfortable, IMO it has enough image quality. How do you think?
#SingleDNG developed in LR Classic and THETA Stitcher.
Good luck!!
Toyo
PS.
If you want to do the bracketing and develop of Z1’s images, you should use PTGui pro. It’s perfect.
Hi Toyo. Thank you very much for your help. May I please ask where you can change resolution? DNGs that I used for HDR have correct resolution 7296x3648 but final HDR image produced by Lightroom has resolution of 1024x512. Also by SingleDNG you mean to just use one DNG image instead of HDR created from several?
Absolutely, yes.
I used to be a tester of Z1 until the official release. That’s my conclusion.
Toyo
Saw an interesting technique on Facebook to combine 3 DNG images.
when i stitching in my system. displayed several green dot line.
I want to solve the problem, but I don’t know the cause.
Lightroom Classic version: 9.0 [ 201910151439-b660523e ]
License: Creative Cloud
Language setting: en
Operating system: Windows 10 - Business Edition
Version: 10.0.18362
Application architecture: x64
System architecture: x64
Logical processor count: 16
Processor speed: 3.6 GHz
Built-in memory: 16231.5 MB
Real memory available to Lightroom: 16231.5 MB
Real memory used by Lightroom: 1926.7 MB (11.8%)
Virtual memory used by Lightroom: 2153.9 MB
GDI objects count: 830
USER objects count: 2786
Process handles count: 3049
Memory cache size: 0.0MB
Internal Camera Raw version: 12.0 [ 321 ]
Maximum thread count used by Camera Raw: 5
Camera Raw SIMD optimization: SSE2,AVX,AVX2
Camera Raw virtual memory: 705MB / 8115MB (8%)
Camera Raw real memory: 706MB / 16231MB (4%)
System DPI setting: 120 DPI
Desktop composition enabled: Yes
Displays: 1) 2560x1440
Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
Graphics Processor Info:
DirectX: AMD Radeon RX 5700 XT (26.20.13031.18002)
Your setup and configuration is fine, I can’t see any issue there.
This looks like a bug, perhaps in the stitcher.
Can you try this on a different machine?
I myself have a workstation on which the stitcher is not working at all. On another one, everything is fine.
Version: 10.0.18362
Built-in memory: 16039.5 MB
Real memory available to Lightroom: 16039.5 MB
Real memory used by Lightroom: 2619.3 MB (16.3%)
Virtual memory used by Lightroom: 2707.1 MB
GDI objects count: 851
Process handles count: 1791
Memory cache size: 1253.6MB
Camera Raw virtual memory: 1141MB / 8019MB (14%)
Camera Raw real memory: 1383MB / 16039MB (8%)
DirectX: Intel(R) UHD Graphics 630 (26.20.100.7262)
I turned off my graphics card and tried again, and it worked fine.
I am suspicious of compatibility with AMD 5700XT and stitching programs.
When I reloaded and tried the graphics card, the same bug appeared again.
Good detective work!
On December 19, Ricoh has provided a new version 1.10.0 of the stitcher with the following changes:
Hello CorLeone,
I have created and HDR image in Photoshop RAW, imported it into Lightroom and exported it as per instructions in Theta Stitcher manual.
I am still getting the ‘No compatible DNG files’ warning come up.
I am using the current versions of all three programs/plug-ins.
I have tried renaming, using filename sequence, but nothing I have tried so far works.
Am I missing something (hopefully!)?
Thanks,
Michael
Did you check this discussion?
I just bought a Z1 and trying to stitch both in lightroom and PS. Neither worked. I am getting a crazy screen preview. Can someone help. I have tried everything for the past two hours.
See this thread:
Hi, there. Inside the Ikoma Cable car, established in 1918. the oldest Cable Line in Japan. It’s called ブル号(buru).
Two different exposure merged in Adobe Lightroom.
Stitched by THETA Stitcher 1.10 version.
f/2.1 ISO80 1/50
f/3.5 ISO80 1/80
I used ISO80 priority mode Ev0 and Ev-1
How do you think? No more overexposure.
Thanks,
Toyo
PS. Removed GMaps URL due to the malfunction of GSV.
